  #81 (permalink)
Old 03-21-2010, 12:36 PM
undy's Avatar
Big cubic inch FEs with a lot of stroke are not go survive for long running above 6K RPM frequently, especially if it's with a heavy scat rotating assembly. It's above 6 grand where a mechanical roller shines, exactly where a stroked FE shouldn't go. Fo a race car, one that takes life 1/4 mile at a time, that might not be a bad thing. For a street driven Cobra, not a good thing.
Oh, ..YES, you can get that lumpy idle with a hydraulic roller. Sometimes it's even lumpier than a similar spec'd flat tappet due to the roller's faster ramp speeds.
Kev, I don't think your targeted solid roller cam's duration is 320 @ 0.050. The 320's probably the "advertised" duration spec. Streetability is entirely gone by 280 @ 0.050".
Too many toys?? never!
  #82 (permalink)
Old 03-21-2010, 12:41 PM
RodKnock's Avatar
Yes, but can you get a sound that makes people ask you "is that the way your engine is supposed to sound?"
It's quite a lovely sound to me. Exquisitely lumpy. Does it sound like my valves need to be adjusted or an exhaust leak? No.
I had a 427/425 (LS6 actually, but same cam) in my Vette and it sounds reasonably close to my ears.
  #83 (permalink)
Old 03-21-2010, 12:42 PM
You should post an audio file. I'd like to hear it.
  #84 (permalink)
Old 03-21-2010, 12:45 PM
RodKnock's Avatar
I should be out in the driveway polishing the aluminum, but alas, not enough time.
  #85 (permalink)
Old 03-21-2010, 01:04 PM
FUNFER2's Avatar
I'de say,....... HELL YEAH !
Music to my ears.
Kevin
  #86 (permalink)
Old 03-21-2010, 01:21 PM
FUNFER2's Avatar
Check out this link from Comp cams about lifters & rockers.
"All models feature EDM Oil Injection"
http://www.compcams.com/technical/FAQ/FAQLifters.asp
http://www.compperformancegroupstore...Code=FELifters
STEVE- I hope this information is what you want ?
I'm also thinking of a mechanical roller so this is why I'm adding to your post. Let me know if I should start my own post !
Kevin
  #87 (permalink)
Old 03-21-2010, 01:39 PM
As I recall, that means "all models EXCEPT Ford FE." If I'm wrong on that I'm sure someone will post a link.
  #88 (permalink)
Old 03-21-2010, 01:49 PM
FUNFER2's Avatar
This page show the Endure-X™ Solid Roller Lifter; Ford (V8 352-428) Solid-Oil Band
PART #839-16
Kevin
  #89 (permalink)
Old 03-21-2010, 01:51 PM
PART #839-16
That's not the same thing. Click on this link and see that they have it for the other size Ford stuff, but not the FE. They clearly tout the EDM when it applies:
http://www.compperformancegroupstore...Category_Code=
  #90 (permalink)
Old 03-21-2010, 02:08 PM
FUNFER2's Avatar
What does this mean then ? "Solid-Oil Band"
PART #839-16
Kevin
  #91 (permalink)
Old 03-21-2010, 02:17 PM
lovehamr's Avatar
Stolen Avitar
The cam type vs. engine type discussion is why I chose a hyd roller. As the owner of a couple of Boss 302s I know a little about revving and I love the tic tic tic sound of a solid cam as well. But the 3" stroke of a Boss is NOTHING like the 4.5" stroke of a big inch FE. Hell, my Boss heads flow as much as my ported Ebock FE heads and they feed 160ci less displacement. This being my first FE, I did allot of reading before I made my choices and all talk of zinging FEs into the 7k+ rpm range on a regular basis should just stop unless it's drag racing only. What were the GT40MkIIs turning down the Mulsanne straight? 5800 rpm or so? And that was with a stock stroke 427. Why on earth would you try to rap out a stroker FE? That being said; without that high rpm (7k+) the need for a solid cam is gone, from an operational perspective that is, and your left with the "I like solids!" argument without any other reason than "it sounds cool." Don't get me wrong, in the world of replicas that is a valid argument/desire; just don't confuse it with an engine requirement.
Steve
  #92 (permalink)
Old 03-21-2010, 02:18 PM
PART #839-16
I'm not exactly sure what a "Solid Oil Band" is other than what they say in their literature (that it controls oil flow), but it is clearly not the same as the EDM oiling holes. Their Elite Series does not have the solid oil band, and they brag about the advantages of that, but it does have the EDM oil holes. You can read about that here: http://www.compcams.com/Technical/Ca...2010/PDF/7.pdf
  #93 (permalink)
Old 03-21-2010, 02:39 PM
FUNFER2's Avatar
Well, this is quoated from the site. But, pay special attention to the
"SPECIAL NOTE" at the bottom. That now concerns me, very much.
COMP Cams® Solid Roller Lifters
Endure-X™ Solid Roller Lifters are fully heat-treated, machined to ultra-high tolerances and fully rebuildable.
All models feature EDM Oil Injection™ technology, which ensures that the roller bearing assembly receives a constant flow of pressurized oil. This virtually eliminates needle bearing oil starvation, historically a “problem area” for all solid roller lifters when used in low rpm and street applications.
COMP Cams® Super Roller Lifters are available for a variety of applications, including small base circle camshaft and offset pushrod seat configurations.
Endure-X™ Solid Roller Lifter Features
1. Patented link bar assembly combines the benefits of a removable link bar with the safety of a captured link bar.
2. EDM Oil Injection™guarantees that the bearing assembly receives a constant flow of pressurized oil via a precision hole aimed directly at the needle bearings.
3. Precision Sorted Bearings -distribute loads evenly, preventing premature wear and failure.
4. Tool Steel Axle -prolongs the life of the roller assembly, particularly in high rpm applications.
Special Note: Solid roller lifters are designed for use in racing applications; however if used in street applications precautions should be taken to avoid excessive idling and certain engine builder modifications are required. Low RPM usage may result in a lack of lubrication from windage, premature wear and ultimately extensive engine damage.
Kevin
  #94 (permalink)
Old 03-21-2010, 02:56 PM
Oh, you mean that "extensive engine damage" thing? Five years ago when I was spec'ing out my engine we were still having exactly the same discussion on solid rollers for an FE. There had been a couple examples of the rollers coming apart, and a couple examples of the distributor gear eat-up. I went with the old SFT set up because (once you break it in) it will outlast you and you don't have to do anything with them except lash them every year or so. I had thought the two solid roller issues had kind of gone away, but I think the truth of the matter is there just hasn't been enough time to really be sure.
  #95 (permalink)
Old 03-21-2010, 03:20 PM
Well that pretty much says it all right there. There have been no significant advances with "long life" in the solid roller category. Same now as it was years ago, use on the street as your own risk.
...your left with the "I like solids!" argument without any other reason than "it sounds cool."
You left out the WAY LESS expensive part of the argument. You can do a flat tappet for a fraction of the cost of a real quality hydraulic setup. For some of us, THAT is a very valid reason indeed!
  #96 (permalink)
FUNFER2's Avatar
After seeing this tid nit of information from Comp Cams, I may even stick with the solid flat tappet type, that I have in my 428. I've never had a problem with them, and after the first year of checking the lash 4 times through the season, I just relief the spring pressure for winter and then only needing lashed once per year now. If I raced my cobra periodically, I would lash before & after. Other than that, no worries.
(damn,... I really like the sound of a solid roller"
Kevin
  #97 (permalink)
Old 03-21-2010, 03:27 PM
If your valve train geometry is setup correctly in the first place there is really very little need to adjust mechanical valves. IF they need adjustment frequently something is wrong, something is wearing out, something is getting ready to let go!
You should be able to "set it and forget it" essentially.
  #98 (permalink)
Old 03-21-2010, 03:29 PM
Jamo's Avatar
Super Moderator
Kevin...me thinks you're making a smart move. Paddy and Oinie have pretty well set forth the situation, and I have posted here numerous times about living with bronze gears and the perfect cutting toll which a solid roller becomes once it has shed it's needle.
Rick will tell you that he continues to experience the new compounds for distributor gears, and maybe the time is coming. But me personally thinks it ain't quite here yet.
Jamo
  #99 (permalink)
Old 03-21-2010, 04:53 PM
FUNFER2's Avatar
Excaliber- I agree, I set them in the spring and that's it unless I've been running the motor hard, even then they haven't loosened much to really worry.
Jamo-Yep, I just don't trust them yet, especially with a very expensive aluminum block.
Good news,.....the sale on my engine is pending payment ! WOO-HOO !!!
Side oiler,..... here, I come !
(can you sence I'm excited) lol
Kevin
  #100 (permalink)
Old 03-21-2010, 05:40 PM
undy's Avatar
That argument might wash if we were exchanging thoughts on, say.. a Nissan Sentra forum, where the vehicles we're discussing are the ones that we rely heavily on for our very day-to-day existence. The very nature of our sport somewhat reeks of self indulgence with a dash of exorbitance. Not a darn thing wrong with that 'cause I are one 2...
Asside from that... Don't forget about the possibility of an engine that's forever "prescription drug" addicted to Zinc additives, not to mention forever living in fear of a dead cylinder miss with thousands of pretty shiny flakes in your oil. There seems to be more and more talk about wiped cams, well after the break-in period these days.
