questions
- » Blogs
- » Image Gallery
million posts!
December 2025
| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
31 |
2Likes
06-05-2008, 06:38 PM
Ut
Here is a pic of the front upright with the steering arm attached. Notice the upper AND lower rod ends are both held in double shear.
Advertising
06-05-2008, 06:40 PM
Ut
This is a pic of the front lower control arm. Notice the push rod mounting location is as far outboard as possible. That is to reduce the bending moment on the front lower control arm as much as possible. You can see we milled the brake line holders directly into these control arms as well.
06-05-2008, 06:42 PM
Ut
Again, on the front lower control arm in the above picture you can see we milled the crotch of the control arm in one motion so the cutter wouldn't stop and make an ugly mark 1/2 way through the arm. We were very concerned about the tool paths on the parts and that they looked good.
06-05-2008, 06:44 PM
Cobra Make, Engine: KMP
Wow!! Simply amazing!!
b/t/w, did you say 15" wheels?
Lew
I'm no expert.
06-05-2008, 06:52 PM
Ut
Si senor...but only if you don't raise your rates to me! So, am I converting you to the Dark Side (billet)?
David
06-05-2008, 07:02 PM
David
..... magnesium bilet (the true Dark Side).
Lew
I'm no expert.
06-05-2008, 07:04 PM
Ut
06-06-2008, 09:18 AM
Ut
Here is a shot of a dual use bracket. This bracket holds the gas tank straps on the bottom and the 3/4 body tubes on the top.
06-06-2008, 09:21 AM
Ut
This is a pic of the rear differential upper mounts. We are using the same differential we use in our own cars, original Cobras, and Shelbys.
06-06-2008, 09:23 AM
Ut
06-06-2008, 09:38 AM
La.
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
sigh ........
Pull a gear .... drop the hammer .... and enjoy the Drive !!
06-06-2008, 10:26 AM
Ut
This is a shot of the support brace that connects the front suspension to the foot boxes--completing the load paths from front to rear. The side pipes normally go through this area, but since the customer wanted under-car exhaust this left a very nice place to tie the frame all together.
06-06-2008, 10:34 AM
Ut
06-06-2008, 10:36 AM
Ut
This shot shows the 1/2 inch gap that will be filled in with the front of the foot box.
06-06-2008, 10:38 AM
Ut
06-06-2008, 10:40 AM
Ut
06-06-2008, 10:45 AM
Ut
This is one of my favorite pics! We milled the outside flange of the hub so it could be used to drive the rotor hat. We did that for many reasons. I was out one day looking at Sandwich's Ducati and noticed the rotor was completely floating on the hat. The reason you float the rotor on the hat is to prevent the dreaded brake shutter. You see, most rotor hats are sandwiched between the rotor hub and the wheel. So, if there is ANY tolerance (unevenness) on the machining of the wheel (always) or the hub (we try very hard to keep that minimal) then the tolerance will show up as a vibration in the brakes. Over the years, people (customers) have gotten less and less tolerant of the brake vibrating.
By driving the rotor hat on the outside of the hub, we completely decoupled the rotor hat from the hub and wheel. Now the rotor spins freely and is able to move left, right, up and down without vibrating the caliper pistons. This was one of my brighter ideas. At least, I think so. We'll see how it works in real life soon
06-06-2008, 10:47 AM
Ut
This shot shows you better what I mean by driving the rotor hat on the outside of the hub flange.
06-06-2008, 10:50 AM
Ut
We made the rotor hat (the aluminum part) 0.005 inches thinner than the flange on the hub. That way, when the wheel is clamped on to the hub, the hat still has 0.005 inches of play. The brake hat can now heat up and expand away from the hub without warping the rotor. Another really cool benefit is there is a tremendous break in the thermal paths from the rotor to the hub--so you don't overheat your hub bearings under hard braking.
06-06-2008, 10:53 AM
Ut
A couple of more comments on the hubs. There is a little step milled into the the back of the hub flange on 3 of the 6 sides so the rotor hat can't fall off the back side of the hub. Also, notice the drive pins are milled directly into the hub. This is the lightest hub we have ever made (and the most expensive one too!)
The hub is made from billet 17-4 PH. The precipitation hardening gives it that cool bronze look.
David
| Thread Tools |
| Display Modes |
Linear Mode
