| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
3Likes
10-21-2011, 04:42 AM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Originally Posted by tkb289
Thanks guys for the posts and info … keep 'em coming. Did some more mock up this evening, still working on the pipe from the collector to the muffler. Located the muffler in it's spot between the frame outriggers and used a 3/4" piece of foam on top of the muffler as a spacer.
Then cut the tail pipe where is fits onto the muffler and hung the pipe from the fender with blue tape. Let me know what you think … maybe move the tail pipe a bit closer to the front of the car and trim of about an inch or so from the end?
Looking at using a hole in the inner fender gusset, to attach a small triangulated support a bracket that will be isolated with rubber, bolt to the frame though an existing hole, then extend out over the tailpipe where it will be welded. Hopefully will be able to fabricate that within the next few days.
Here are some photos …
Muffler 'in place' with a 3/4" foam spacer
On the ground (well almost)
Muffler and pipes will be flat black when finished
Slightly different view
Looks pretty good, but I think that painters tape is only good to about 55 mph. If you want it to hold together, I think you need to use some 200 mph tape instead.
Replica is not a dirty word.
10-19-2011, 03:47 AM
MA
Go look at the last page of the "289 ffr build" the green original car has a picture of an under car exhaust the opening of the pipe ines up with the line of the rear of the door opening
10-19-2011, 06:07 AM
Kevin,
Thanks for the lead, found the thread and jmimac351's post ...
289 Body on FFR mkIV chassis
That sure looks like CSX 2472, the restored Dragon Snake that was at SAAC 35. I saw the same car at the De Anza College car show and took these photos. The 'exhaust' is just a straight pipe and when they fired up the car it sounded great and very loud!
Also have some photos I took at Laguna Seca of barn find CSX 2289.
Both give good examples of where to exit the pipes, and how long to have them stick out. It also looks like heat from the exhaust does not appear to be damaging the paint, no fiberglass to melt on these cars
CSX 2472
The pipes on 2472 look like they have about a 45 degree turn out very similar to the ERA pipes
CSX 2289
These pipes have a simple 90 degree turn out
Have to say in looking at the two setups, I like the 45 degree look of the pipes on 2472 ... ERA chose wisely
Any more examples ?
10-19-2011, 08:37 AM
PA
Cobra Make, Engine: ERA FIA #2124
Tim:
I think one thing we can learn from the pictures above is that these cars were all a little different in this department at any given time in their useful lifetimes. I would suggest you just do what you think looks "good" to your eye. For me, it would be something like this:
I would cut it per the red line visible in this quick drawing. Personally, I would think that as long as the pipe is cut flush with or a bit inboard of the rear wheel well contour line, you will be in a good place visually. Just my humble opinion.
- Allen.
10-19-2011, 10:21 PM
Originally Posted by Fullchat289
Tim:
- Allen.
Allen,
Nice drawing and nicely put. I think you are correct, when the pipe looks right ( to me  ) I'll know it.
Plan to work on the car this weekend and will likely have the pipe end midway between the body line and the wheel well contour line, similar to your sketch but with the tip a bit shorter and with a square cut end, versus the angle cut.
Have always liked the square cut and not sure why, it's all in the eye of the beholder I suppose. Thanks for the feedback, really appreciate it!
10-20-2011, 04:25 AM
PA
No problem, Tim. I like the squared-off cut also. I'm sure it will look great in the end!
- Allen.
10-21-2011, 01:34 AM
SA
Hi Tim. Just saw on the Mark Reid exhaust post, Allen's picture of the blue FIA with the white exhaust. Not suggesting the colour, but the bend coming out at around 10-15 degrees, so still underneath and safe enough, then a short bend at the end....looks OK. Not sure if it fits with your hanger though.
Glen
10-21-2011, 02:24 AM
Glen,
Saw Allen's photo of the beautiful princess blue FIA ( nice color by the way  ) with the white exhaust pipe that angles out, then the short bend. Looks like it could be a short glass pack under the car, or just a straight pipe for racing and it suits the car very well.
Either way your right that it won't work with the muffler / hanger setup that I have from ERA. The white wheels, roundels & exhaust make for a great look.
11-13-2011, 09:04 PM
It took a while, but the exhaust system is done. We wound up shortening the collectors about 1 inch, which now has the head pipes parallel with the frame rails and there is a 3/4" gap between the top of the muffler and the bottom of the car. There is also room between the head pipe and the brake pedal box.
The bottom of the muffler is just about even with the bottom of the frame rail … just like Bob said it would be ...
I fired it up and it sounds great … the real test will be when I drive it. I took the entire system apart and it's at the coaters ( Accessories Plus in Belmont, CA. ) being ceramic coated satin black. More photos when I get the parts back.
In the mean time, trying to wrap things up to get the car on the road ...
Exhaust system is done !
Fabricated a hanger that bolts onto the frame near the rear suspension. The rubber sheeting makes for some compliance in the system, used existing holes to mount the hangers … did not want to drill into the frame if possible.
The 'kick out' angle in now 70 degrees. A bit more than the ERA bend, but less than a 90 degree turn.
11-13-2011, 09:28 PM
GA
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
Looks great! BUT, we need to see some rock chips in on those rear quarters!! It's tight under there isn't it!! Regards, Matt
11-14-2011, 07:41 PM
Neutral
That came out really well, the angle and placement and the square cut outlet. Very nicely done.
12-05-2011, 08:27 PM
CA
Tim,
What's the latest? Just in time to get that car on road for some prime time (freeze your axx off) NorCal weather!
Doug
12-05-2011, 09:59 PM
Originally Posted by Got the Bug
Tim,
Doug,
Thanks for checking in!
Hope to be on the road quite soon … just love that ar$e freezing weather !
Update to follow ...
- Tim
12-05-2011, 10:15 PM
Have made some good progress of late …
Had the entire exhaust system ceramic coated (satin black) by Accessories Plus in Belmont, CA. Steve and his crew did a great job.
The coating is about 0.002" thick, so no real issues with slip fits. I used a bit of copper based anti-seize, and with a little gentle persuasion here & there, everything went together.
Next up is finishing the interior, seats & seat belts and 2136 is ready to roll.
I have some mandrel bent pipes coming that are much more substantial, so these pipes here just are 'temporary'.
Everything fits nicely under the car, the time spent during the 'fitment' process was well worth the effort. It really sounds great.
Once I get some miles on the car, the suspension should settle a bit, looks like the car is up on it's tip toes ... it needs to come down some.
12-05-2011, 11:57 PM
SA
Beautiful job Tim, and it looks like the trees haven't lost all their leaves yet, so maybe some good driving time still available this season?
Glen
12-06-2011, 03:52 AM
OR
Very nice!
ERA FIA 2088
12-06-2011, 12:45 PM
NY
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
To "settle" the suspension, call up one of your larger (ie; 250 lb =/-) friends and go for a drive on some back roads with a few "thank you ma'm" culvert crossings, etc. An hour or two of driving should bring it right down...
Jim
12-08-2011, 03:04 PM
CA
Tim: that looks great! Been wanting to drop by and hear it (1/2 the time I drive home along Homestead).
Have you given thought to which CHP, BAR and B&L station to take the ERA to once it's roadworthy?
12-08-2011, 10:05 PM
Herman,
When I get to that point, thinking of trying the Dublin CHP office, based on a recent thread. For BAR I understand Evergreen college is the place to go. For B&L ... open to suggestions.
12-26-2011, 08:14 PM
CA
So Tim, did you ever make it to a Christmas drive around the block????
| Thread Tools |
| Display Modes |
Hybrid Mode
