06-13-2011, 09:22 AM
AL
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Good eye. They are too long and i am changing them out. They are great 8 though. I need to place an order with McMaster for some other fasteners and better radiator hose clamps as well.
06-13-2011, 10:20 AM
Full Blown Member
Looks awesome!
Can't wait to see it completed.
Fun thread.
rodneym
06-14-2011, 10:26 AM
AL
Thanks!
Driveshaft bolts:
Ok, i just ordered high strength bolts with a rockwell harness of C25 and minimum tensile strength of 116,000 PSI with high strength 12 point flange nuts with a minimum rockwell harness of C34.
Hopefully that will hold it. Im just now educating myself on the rockwell and tensile strength scales/charts/tables
06-24-2011, 07:42 AM
Cobra Make, Engine: CSX6363
Looking great Chris! I was home on R&R a few weeks ago and spent most of my time either at the lake or white-water rafting so we never headed in your direction. Like everyone else, I'm eagerly awaiting the day that you have this car out on the road. Send the girlfriend down to the beach for a few more weekends and you'll have a better chance of having the car running w/in the next month!!!
06-27-2011, 08:38 PM
AL
haha Mike! If only dating/female companionship and sleeping weren't such a strong human need.
I'm working on the sidepipe cutouts tonight. Not much else to do while i wait on the bulkhead to be powdercoated and a few parts to come in from summit. Hopefully the little parts will be in soon. Im not going to attempt to start the car again until at least the header tubes are hooked up.
06-28-2011, 08:42 AM
AL
I had a good time with my new 20.00 high speed cutting saw last night. The holes had to be enlarged quite a bit. Initially I thought i would be able to make the cutouts similiar to how the kirkhams cut them, but the hole had already been cut too far back at the top, so i just ended up making sort of an oval shape.
It took 4 hours to cut this hole out. I had to install a pipe, remove a pipe, make a cut, install the pipe again, make another cut, remove the pipe, etc and so on. Im pretty happy with how it turned out. I went very slowly to make sure that i did not cut a hole too large.
Initially, i thought i was just going to need to give it a light trim, but once I installed the number 1 header tube, it was obvious that a good bit of metal needed to be removed.
06-28-2011, 11:11 PM
IL
Cobra Make, Engine: Kirkham #647 brushed
Looks good Chris! I'm glad it worked out  if you put some metal edging on it, it could reduce the hole size a bit.
06-29-2011, 02:27 PM
AL
I might do that to prevent it from chipping as well. The hole actually looks quite normal when you look down on it from a normal height. If you get down on the ground and stare at it, it looks a little too big, but I really dont think most people will be crawling around on the ground looking at the sidepipe cut out.
06-29-2011, 05:33 PM
A bare aluminum surround piece could finish it off nicely and help close up the gap.
07-01-2011, 12:45 AM
UK
No. Once the edge is cleaned up and painted, it will look fine.
I thought the gaps an mine were on the large side to start with, but now I'm used to them, they look exactly as they should.
The rear edge of the hole should be angled backwards i.e. the hole is wider at the bottom than it is at the top.
Looking good. I'm looking forward to seeing it all finished. My only comment would be that the side roundals and numbers are on the small side, but I assume they're just stick on, are they?
Paul
07-07-2011, 10:04 PM
AL
I could not cut an angle in for the side pipe cut outs due to the hole that was already cut. I cant paint the cutouts that i have made because i have no idea what color paint cinema vehicles used on the car.
The gumballs are the ones that they, cinema vehicles, stuck on for the movie, so they will stay. And you are correct, they are just stickers. Im not the biggest fan of gumballs, but i am trying to keep the car looking as close to the way it was built for the movie as possible. Actually, if was building one from start to finish, it would be black with no stripes.
07-08-2011, 12:07 AM
UK
Good point. I'd actually forgotten it was the Iron Man car, so of course you want to keep it as close as possible.
We have a franchise company here in the UK called Chipsaway, who can match and paint pretty much any paint defect. They specialise in stone chips and scratches and operate from fully equipped vans, so they can go to the customer. I would have though there were similar companies in the US.
Putting an edging trim around the hole just won't look right, IMO.
Looking at your picture with the tape measure, that dimension is about right for the top of the hole. I've just been out to the garage to measure mine and it tapers from around 6" at the top to around 8" at the bottom. If you hole has parallel vertical sides at around 6", you can still get the correct taper.
Paul
07-08-2011, 07:46 AM
AL
Paul, if you take a second look at the tape measurer, the top of the hole extends back to 8" on both the top and the bottom. The only way i could taper the hole at this point would be to take the bottom out to 10", which would look really bad. The hole honestly doesnt look ginormous at any angle. Perhaps a little large when viewed while lying down on the ground, but other than that, it looks more or less normal. And honestly, if the hole was any smaller i would not have been able to stuff the headers tubes through it to connect them to the engine. I'll take another picture of the car from the height where it will normally be viewed and post it later today. Currently I just want to get the car finished and on the road. Little details such as the exhaust cut out can be addressed later if they start to bother me or the paint ends up flaking or bubbling due to heat.
BTW, the engine is a alive and running. I'll have a video soon.
07-08-2011, 07:53 AM
UK
I noticed the rear of the hole was at 8" on the tape, but the front of the hole was at 2", so I figured 6" in total.
The hole looks fine and about the same size as mine at the top, which was why I assumed you still have room to taper it out at the bottom.
Paul
07-08-2011, 08:00 AM
IL
Woohoo! I hope I get another Birmingham overnight soon
I got more pictures heading your way today Chris.
07-08-2011, 11:56 AM
AL
That was an in progress photo before i had to cut the front to make the two front bound pipes fit. I thought i was going to be able to get away with trimming them less towards the front, but i was very incorrect. The hole actually ends up being right around .75" out from the start of the fender flare. It's pretty close to the fender, as I am sure you are well aware of. I never even realized that the holes were tapered from the Kirkham factory until i saw Arnaud's photos of the arrival of his car. I wonder if they have always tapered the sidepipe cutouts.
Thanks Arnaud! You da man! The pictures have been very helpful so far and i really appreciate you taking the time to send them to me. I am not looking forward to cutting the foam and putting it in the wheel wells, but I am sure your pictures will make the task much more painless.
07-30-2011, 09:55 PM
AL
Finally got the panels back from the powdercoaters.
Dont make fun of my AC Delco battery, it was free.
I've decided to go with the black rivet. They just look better in my opinion. Ill post more pictures once i get it all in place. The smash rivets for the fender portions were not fun to install.
Before
Almost After
07-31-2011, 12:10 AM
You're getting super close to finishing the car......how much longer before the inaugural start??? I checked the calendar and I have 105 more days of fun in the sun and about 120 before my CSX rolls into my garage.
07-31-2011, 09:24 AM
AL
Mike, its been up and running, but i had a bad Magnentic pick up, some fuel pressure issues, and i am still chasing down issues with the MSD system. I also have an oil leak at the oil pan drain plug for some reason, so i am going to need to drop the pan and probably rethread the plug hole. Perhaps i overtightened the drain plug and messed up the threads.
Ill be tackling the rest of the interior today and the wheel well foam while i have the car up on jack stands.
It's very close to being finished, but i still have a long list of small items to tackle.
I hope the next 4 months fly by for you. Stay safe!
07-31-2011, 10:16 AM
Looking great!
