Like Tree394Likes
LinkBack Thread Tools Rating: Thread Rating: 17 votes, 3.12 average. Display Modes
  #1161 (permalink)
Old 10-10-2015, 10:16 AM
1985 CCX's Avatar
Alternator pivot bolt locking nut is a great detail.
Also adding the alternator pulley plate.
  #1162 (permalink)
Old 10-10-2015, 10:28 AM
1985 CCX's Avatar
Winter project is getting Dow dip on the mag FIAs.
Racewhere to help...... Will protect the wheels form Mother Nature.
Thanks again John!
  #1163 (permalink)
Old 10-10-2015, 10:54 AM
1985 CCX's Avatar
John and Bella take Avons and convert to Goodyears.
Blue streak too.......
CompClassics likes this.
  #1164 (permalink)
Old 10-10-2015, 09:48 PM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Thanks again John!
Jeff,
Those wheels look great. Are they the natural magnesium color or have they been coated (paint, powder coat, etc.)
Ted
  #1165 (permalink)
Old 10-10-2015, 10:56 PM
CompClassics's Avatar
The wheels have the original DOW coating. I can't wait to see the photos of the installed parts that we provided to you! Thanks for taking the time to come and see us in Escondido, next time dinner is on us! John
  #1166 (permalink)
Old 10-11-2015, 03:31 AM
*13*'s Avatar
Looking towards adding new cooling tube to the buggy.
Will allow for changing alt belt with ease.
That's really nice! I rerouted mine earlier this year. Had it going through the belt, as well.
ERA FIA 2088
  #1167 (permalink)
Old 10-11-2015, 08:23 AM
Shootnride's Avatar
John,
Thanks for the reply. Could you elaborate a little about the DOW coating. If applied to an aluminum wheel would it give the same appearance. What is the process to use this coating.
Ted
  #1168 (permalink)
Old 10-11-2015, 03:21 PM
The DOW process was used as a primer for magnesium primarily in the aircraft industry. When magnesium is exposed to oxygen it causes the magnesium to oxidize or corrode, the DOW process protects the magnesium from this. A lot of people believe that you can paint over magnesium this isn't advisable, the magnesium will start oxidizing between the painted or powder coated surface and the magnesium and this may not be detectable until the surface finish ruptures or cracks exposing the tell tale "worming" effect. I f you have magnesium wheels either get the DOW treated or use a product called "Gibbs" and apply to all of the exposed metal surfaces including the area between the rim inner and outer beads. DOW can not be applied to aluminum wheels, aluminum requires anodizing processes, which vintage wheel manufacturers use today to achieve the magnesium DOW look.
  #1169 (permalink)
Old 10-11-2015, 03:24 PM
The DOW process is a chemical "pickeling" of the part, the first step is a hot immersion and the second is an immediate cold immersion sealing the chemical in the magnesiums pores.
FYI, we can apply the "GOODYEAR" or other lettering to most any brand of tire, there are examples of some BF Goodrich tires that we did also on the forum.
  #1170 (permalink)
Old 10-11-2015, 06:22 PM
Shootnride's Avatar
John,
Thanks for taking the time to explain the DOW coating process. I was aware of the issues with magnesium corrosion/oxidation but knew nothing of the DOW treatment. Very interesting.
Thanks again
Ted
  #1171 (permalink)
Old 10-12-2015, 08:45 AM
1985 CCX's Avatar
Before:
  #1172 (permalink)
Old 10-12-2015, 09:03 AM
Cobra Make, Engine: era 427 side oiler
looking for a fuel inlet splash shield for a fia 289 cobra? regards Domenic Saia
  #1173 (permalink)
Old 10-12-2015, 09:40 AM
LMH's Avatar
LMH LMH is offline
Jeff, your belt looks a little wide for the pulley. Is that a .375" wide belt?
Alba gu brąth
  #1174 (permalink)
Old 10-12-2015, 01:37 PM
1985 CCX's Avatar
Larry,
Might be, put a cheapo on it to see if alignment was ok.
After .......
LMH and CompClassics like this.
  #1175 (permalink)
Old 10-12-2015, 01:44 PM
LMH's Avatar
LMH LMH is offline
I know Dan's tech drawing of the belt lettering lists the original belt as .375" wide, Gates 8220. If the pulleys are period, they would be set up for that width belt. Not wanting to pick nits of course, you know me! It was just a thought as I stared at your pics!
Alba gu brąth
  #1176 (permalink)
Old 10-12-2015, 02:40 PM
1985 CCX's Avatar
The length is funny due to original alternator bracket.
Have not been able to find 49.5"-50" version
Am I searching in the wrong place?
  #1177 (permalink)
Old 10-12-2015, 03:54 PM
LMH's Avatar
LMH LMH is offline
I think it's supposed to be 48" but haven't tried it real world. Do you think that would be too short?
Alba gu brąth
  #1178 (permalink)
Old 10-12-2015, 04:44 PM
1985 CCX's Avatar
Might be tight as current belt 50.
Only little play.
  #1179 (permalink)
Old 10-13-2015, 01:05 AM
ALF's Avatar
ALF ALF is offline
Great visit with John at Racewhere.
Bella and John have a great shop, know how and the right stuff.
And they have the right attitude to thread their customers on an outstanding way.
- Great know how
- Great parts
- Great customer support
Only great!
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #1180 (permalink)
Old 10-26-2015, 04:01 PM
Jeff,
I've found your ultimate tow vehicle!!!
