3Likes
02-25-2010, 07:18 AM
OR
I think the Torq's would be awesome! Be different!
ERA FIA 2088
02-25-2010, 08:47 AM
Cobra Make, Engine: ERA 289FIA 2131, 331 stroker by Dan Dalena with 48 IDAs by Jim Inglese, AC Cars AC8 "Rosso Chiaro" (PPG Nexa code FG39) by Connecticut Custom
Looks great! I'll hopefully visit ERA again while it is still there.
02-25-2010, 10:04 AM
Originally Posted by tkb289
Rodney ... you will not be surprised to hear that I am debating FIA wheels with white or black centers & polished rim OR Torque Thrust D, black spokes with polished rim ... hmmmmm
While I'm a big fan of Torq Thrusts, I would run FIA's either in the natural cast finish or paint/powdercoat them white. But that's me. What do you want?
I almost ran FIA's on my 427, so I really like the wheel.
02-25-2010, 11:26 AM
fl
Couldn't go wrong with either one. I wanted to use TorqThrusts but couldn't with the larger brakes -went with Vintage 427 style wheels on my FIA. Nice wheels look great.
02-25-2010, 11:51 AM
Tim: Looks great. Love the color.
DD
Dangerous Doug
"You're kidding, right?"
03-22-2010, 07:27 AM
Well 2136 has been back from paint for a little while now and courtesy of RAO-3 (thanks Ray), here is a photo taken at ERA late last week ... you can just see the nose peeking out from under the cover.
I have been talking with Peter about the final build list to turn the car into a roller. Once that is finalized, and my turn comes in the final assembly area, 2136 will be one step closer to being on a truck headed West! Looks like there is no shortage of cars in various stages of completion at ERA
The plan is to have ERA build it out to a roller, but not a turn key car. I'll have the motor and transmission installed out here.
03-24-2010, 09:49 AM
03-24-2010, 09:51 AM
Wow!
Wow! If it looks that good on a computer screen it must be absolutely stunning in real life. I really like it.
03-24-2010, 10:09 AM
NC
Cobra Make, Engine: ERA #775
It's a beautiful deep blue, which I'm sure will look even better out in the daylight. I think that all tkb289's work in trying to pick the 'right' color worked out well; I really like it.
-Ray
03-24-2010, 10:21 AM
Tim, gorgeous. Excellent choice.
So, did you figure out what color the block and wheels are going to be?
03-24-2010, 10:57 AM
So do I and so I did...
Chas.
03-24-2010, 12:34 PM
F' in SWEET!
03-24-2010, 08:11 PM
Thanks guys … and thank you Jeff for the photos, they are great! Connecticut Custom did a wonderful job. I am looking forward to seeing the car in person. In the sun, it should be a nice vibrant blue, depending on how the light plays on the paint.
03-24-2010, 08:18 PM
Rodney ...
Good questions
The easy part, the block will be painted black.
The wheels … still pondering that one  ... Plan on going with pin drive, and either the FIA or TTD (current version) wheels (15").
- FIA wheels: I'll go with the web either as cast or black web, possibly with a polished lip, silver spinner.
- Torque Thrust D (Pin Drive): Black spokes with a polished lip, silver spinner.
I really like the white FIA wheels on the Coupe and on the FIA race cars and would also consider them on this car. However, since this car has no hood scoop, oil cooler scoop or FIA stripe, but will have a grille … I'll have see how it looks with the as cast or black web FIA wheels. I can always paint them later.
03-24-2010, 08:39 PM
Jeff,
Sent you a PM.
- Tim
03-24-2010, 08:54 PM
Looking good Tim!! Tell those guys at ERA to stop slacking off and deliver your car to you.
When are going to spill the beans on your engine choice??
Doug
03-24-2010, 08:56 PM
Cobra Make, Engine: ERA 427 - #783
Jeff also took this pic - which has my #783 by the lift, Ray's #775 in the foreground, and Tim's 2136 against the wall. I don't know who else is in the pic. I have to say Tim, that paint looks nice.
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
03-24-2010, 09:10 PM
Mooch,
Thanks for posting one of Jeff's shots, it tells a great story!
- Tim
03-24-2010, 09:16 PM
There sure is a lot of blue in ERA these days...
Mooch
ERA Registry Map
03-24-2010, 09:33 PM
Thanks Doug ... Yeah ... yeah, I'm working on them. About time to send another care package  . The guys at ERA are busy as you can see, and as other cars are shipped off to their happy new homes, it puts me that much closer!
The engine beans are still cooking  I have been working on the recipe and have some good leads for a chef. I suspect I'll be ready to serve some up soon.
The basics are still pretty much the same ... something with some decent power, runs well, does not leak or self-destruct.
- 302 Iron block
- AFR Aluminum heads
- AVIAID or Canton Oil Pan
- Roller cam (specs TBD)
- 650 cfm carb with 289 Hi-Po style air cleaner
- Mechanical fuel pump
- PCV setup
- Vintage '67 289 stamped steel valve covers
- Black distributor cap and wires
- A distributor gear that is compatible with the cam (don't want any surprises)
- Quicktime bell housing and external slave cylinder
Pretty basic stuff, and there are a lot of good options out there. I'll let you know when the beans are done !
